Thread: Heater Blowers
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default Heater Blowers
    Hi guys, everytime i turn my ignition on the blowers automatically start blowing at settin 7, is there a way to stop it?
    Mileage : 000
    If you have climate control then it will do that, you can adjust the cabin tempreture to one that is nearer to the outside temp" or turn the big knob in the middle to a manual setting, these are what I do to stop it blowing my head off when I first get in.
    S.Wales, Nr Swansea
    so its normal and most vec-c's with climate control do this?
    Mileage : 000
    Yes. you see the sensor on the top of the dashboard "reads" the tempreture in the cabin, then adjusts it to what you have set it too, ie, if you set the CC to lets say 19 degrees and the sun has warmed the cabin to 26degrees then the sensor will say it is too hot in the cabin so the CC will need to reduce the tempreture down to 19 degrees so it will blow like made, to cool the inside of the car, hope this makes sence to you now. you might notice that on a cool morning the blower will not start of blowing like mad, as it has no heat to give you as the engine is cold, then as the engine starts to warm up , you will notice that the blower will start to blow harder as there is more heat for it to blow out.
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    mine will only do that if the screen defost is selected. once its unpressed its fine.
    S.Wales, Nr Swansea
    Quote Originally Posted by ed taylor
    i understand now mate, thank you very much, i have my setting on LO all the time
    Mileage : 000
    Veccy c gsi, glad to be of some help, but you must have been very cold when the CC was fully working. if you in the morning when the window,s are misted up press the DEF buttton it will blast at full poewr and demist the screen.
  1. Blowers not working
    By DJM in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2012, 19:06
  2. blowers
    By bown in forum Introduce yourself.
    Last Post: 9th November 2010, 22:42
  3. no blowers/heaters 3.2 gsi
    By vegasbaby in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2010, 23:39
  4. my blowers
    By stuee in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:39
  5. No heating or blowers!
    By Butler in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2008, 21:01
