Thread: Vectra c has MAF??
    Regular Member bedo13's Avatar
    Oct 2009
    EgypT
    Lightbulb Vectra c has MAF??
    Hello everyone
    I want 2 know if vectra c has MAF sensor or not?
    Mass air flow sensor..
    If yes, what is its position?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yes, follow the tube coming from the airbox lid, there will be a cable coming out of it. That's the MAF sensor.
    Gazza4
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Oct 2009
    EgypT
    So what will happen if there is error from it??
    Can i test it??
    Normally if there is an error with the MAF the Engine Warning Light will come on AND the engine will go into Safe Mode
    I use this as a test of the system as it is one of the easiest main sensors to get to
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you can take it off and clean it with component cleaner, brake and clutch cleaner will do the same job...
    Oct 2009
    EgypT
    Thanks, but is there any way i can test MAF?
    Jun 2009
    South Coast
    Tech2 or Opcom will show MAF specific fault codes if it has a problem... you can buy replacement MAFs from vauxhall parts specialists on the net a lot cheaper than the dealers.. Replacing the MAF at the right price it will be cheaper than paying an hour for you car to plugged in to diags..
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
