Results 1 to 10 of 16
Thread: MOT Testers - Help!
    Regular Member vectraboyy's Avatar
    Default MOT Testers - Help!
    Hii,
    My car went in for a MOT and cambelt Tueasday, and well what can i say!
    I got it back, walked into the car park and the engine warning light was on. It got turned off and cleared but came back on again last night.
    They have said that it came on when they did the smoke test and its 'just ot clogged'
    Now in a year of ownership i have only had to have clutch/DMF replaced, spending £366 on a cambelt and this has thoroughly annoyed me!
    I'm sure that the car is meant to be gotten upto 80degress or as close to possible for the test. If this is done, then there should have been no consequences at all.
    Can anyoen confirm that this is true?
    11 Post(s)
    Quote Originally Posted by vectraboyy View Post
    http://www.motuk.co.uk/manual_740.htm
    When to do the test
    The smoke test must only be completed when the engine is at normal operating temperature.
    It is not normally sufficient to run the engine with the vehicle stationary to warm it up to temperature
    The engine oil temperature measured by a probe in the oil level dipstick tube is to be at least 80°C, or normal operating temperature if lower (60°C minimum). Testing an engine below normal operating temperature may affect the test result
    Thats what i thought!
    Ashington, Northumberland
    I am nominated tester and yea, the smoke machine oil temp probe will sample the oil temperature and will not let you proceed with the test until the oil is at the correct temperature. However, some machines will allow you to bypass the oil temp check, and a lot of testers do this if the temp guage shows the engine is hot. Not really best practice to bypass it, but it does happen. I never do, because then the oil temp is on the printout which goes some way to covering me should anything happen. It shows I've carried out the procedure correctly.
    Quote Originally Posted by GARY3306 View Post
    The MOT readout has no temp on it as they haven't taken and recorded it.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    If they've interrupted a regen then this may have happened, dpf clogged until its been run and cleared out... Got caught out on mine like this....
    Quote Originally Posted by plasma View Post
    No DPF!!
    My light is back on now as well
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    well thats my theory shot then.. Need to know the code...
    I know, i dont know where my Opcom is though
    Engine : 1.9 CDTi
    Where are you from?
    Someone local might be able to help.
  1. One for the MOT testers...
    By Samdy Gray in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2012, 17:56
  2. PAT testers
    By DaveDempsey in forum General Chat
    Last Post: 13th August 2009, 09:09
  3. Mot Testers Manual
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 15:36
  4. How do you use one of these antifreeze testers?
    By muffking in forum Engine & Drivetrain
    Last Post: 10th January 2007, 14:19
  5. Testers needed
    By Spikey© in forum General Chat
    Last Post: 8th November 2006, 14:11
