Thread: Air con problem
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    StatsVehicle Info
    Default Air con problem
    Hi Guys,
    For the first time I tried the aircon on my vectra C today but the air seems tepid not cold like it should be. The manual says that it'll only get as cold as the coldest setting on the adjustment knob, which is I think 17 degrees (I might be wrong) and that's not cold enough for an aircon. The previous owner said it's been recharged 6 months ago.
    Any explanations/ help will be appreciated.
    Az
    North Wales - Assistant Regional Organiser
    Wirral
    StatsVehicle Info
    The air blowing out of the vents should be considerably colder than 17 degrees. It's possible the system has a slight leak and the refrigerant has leaked out hence needing the re-gas in the first place. A good air-con company should be able to flush the system and put a dye in to see if there's any leaks. What was the outside temperature at the time? The air-con system won't kick in even if the button is pressed if the temperature is below 4 degrees outside I think.
    Regular Member Envy's Avatar
    Welwyn Garden City
    StatsVehicle Info
    When I got my Vec the Air con blew warm. I took it back to the dealers to be regassed. Lasted about a week then started to blow different warm temps out of the front air vents. When I took it back again to moan they found around 5 leaks in the condensor and had to order a replacement part. It took 2 months to get the part as they seem to be a weak spot on the vecs and in demand (mine is a 06 facelift)
    Now it works fine but I did place some wire mesh behind the front lower grill to protect it from stones etc.
    I would get it checked for leaks first to be sure
    Sep 2009
    Glasgow
    StatsVehicle Info
    mines was the same condencer had a hole in it, once fixed and gassed my temp goes down to around a chilly 4.8 - 5 degrees.
    StatsVehicle Info
    Quote Originally Posted by azacbr6 View Post
    Hi Guys,
    The AC needs to be used regularly to stop the rubber seals from drying out (at least once every 2 weeks - even in winter). Not only is there refrigerant inside the AC system, there is oil too.
    6 months is a long time for it not to have run. I suspect at the very least it will require a recharge again. Hopefully the seals will recover and soften up once they've been soaked in oil again.
    Sorry if this is teaching granny to suck eggs, but you can use the heater in conjunction with your AC - it makes for a quick demister. It's not only for using in the summer to keep the cabin cold. Use it all year round, or lose it.
    Dec 2010
    chesterfield
    StatsVehicle Info
    No You are right in that Big Dave, I assumed things were done and it was regassed and I left it at that.I will have it checked next week and get it sorted. I have the bill to prove that it was regassed but unfortunately there seems to be a problem, leakeage probably.
    Will let you know what I find out.
    And my car is an 07 CDTI 150 if that makes any difference.
    Thanks for the useful Info/Advice, Much appreciated.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
