Thread: Spanner light on 1.9cdti (150) veccy est
    Mar 2011
    Hull
    Default Spanner light on 1.9cdti (150) veccy est
    Hello. I have been looking on the forums for a possible answer to a spanner/car light on my dash. But I am new to forums and not sure I am seeking my salvation in the right manner.
    Anyway here goes. As mentioned spanner/car light on dash, started a few days ago, but light would go out after start up. Today light stayed on continuously and I noticed that the temp gauge rose, then settled back down, though it was slightly higher than its usual running temp, rise fractionally then settle. I have not experienced any limp home mode. But it does seem to have a flat spot until about 2000 revs.
    Any suggestions would be great, and thank you in advance.
    11 Post(s)
    Fault code(s) need reading out.
    It's a more reliable method than guessing.
    You might be able to do the free pedal trick - see the how2 section for, er, how2.
    Mar 2011
    Hull
    I will give it a go. If not, will try and find a back street car wizard with a code reader, to plug in and scan. Any ideas how much I should be looking to pay for a fault code scan?. Desperately want to avoid dealer. Is there a code reader on good ole EBay that would do the trick, or would I be urinating in the wind.
    Mar 2011
    Hull
    Tried pedal trick to view codes, but no joy. Bought an autel gs500, but this tells me that no MIL is on, and does not read any codes. This is getting on my nerves now.
    When driving my car I have full power, seems to run as normal, just the temp gauge is a little higher than normal. But light being on is maddening.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  3. Vec C 1.9CDTi 16V: Yellow spanner/EML/temp gauge?
    By Cavec in forum Vectra C / Signum Troubleshooting
    Last Post: 11th February 2010, 07:49
  4. lol 1.9cdti 16v spanner light??
    By gaz130 in forum Engine & Drivetrain
    Last Post: 4th March 2008, 11:44
