Thread: egr making a buzzing noise
    Mar 2011
    kent
    Default egr making a buzzing noise
    hi all signum 2.2dti with spanner light and idle problem when up to temp(90), cleaned everything still got prob have noticed my egr buzzing is this normal has anybody else heard there's do this any advice?
    Sodding Typical on Sea
    Sounds as though the solenoid is jamming and trying to engage / disengage hence the buzzing.
    Mar 2011
    kent
    Thanks for getting back,I think it's a new noise and appeared after cleaning it do you think i've knackered it?
    Hmmm,,,,,,,,, cleaned it, did you interfere with the solenoid? and did you grease it all up again?
    Mar 2011
    kent
    didn,t play with the solenoid just cleaned off all the soot/carbon build up with carb cleaner didn't think about greasing it up, i take it grease won't affect any other sensors
    The grease would only be on the shaft of the solenoid but if it was an external type clean I am wondering if it has still jammed?
    Mar 2011
    kent
    gonna take it off again 2mrow clean again and grease will also check under grey cover see if i can see anything untoward...cheers
  1. headlights making a noise
    By robg81 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2012, 17:58
  2. Buzzing Noise
    By Wolfie01 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 13:08
  3. Buzzing noise from speakers
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 17:59
  4. buzzing noise
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2008, 19:26
  5. buzzing noise after i turn ignition off?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 10:20
egr still making a buzzing noise
car egr sound buzzing
