Thread: Cambelt and water pump changed today
    Regular Member marky2027's Avatar
    Northumberland
    Smile Cambelt and water pump changed today
    Well after buying the cambelt kit, aux belt and water pump last week they have been fitted today by local garage. He said that both the pump and the belt were not really in that bad condition (car's done 70k) but I've got peace of mind now it's done. £260 all in. I'm happy with that
    lincolnshire
    you dont say what engine you have ? but if its a CDTi then your def better having it done early bud
    Northumberland
    Oh aye forgot that bit........1.9 cdti 150
    lincolnshire
    def a good choice gettin it done then matey !
    Quote Originally Posted by marky2027 View Post
    Might visually look acceptable, but when compared to a new item the used cambelt is usually easy to recognise and can be longer
    The waterpump is a different matter as the main bearing tends to just fail suddenly
    Do the next cambelt kit at around 40K miles, and at 80K miles repeat the process with all three
    The main thing you are looking for on a removed cambelt is oil and/or broken, damaged, missing teeth
    I've only had it once
    Northumberland
    Looking to keep the vec another year or so. Will be changing it next summer probably but couldn't take the risk of not getting it done especially since we drive to France on our hols.
    Regular Member badback's Avatar
    Runcorn
    I think it's a no brainer changing the water pump aswell. Mine was done at 65K and the pump was close to failing. Well worth it for peace of mind.
  1. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  2. How to tell if the Cam Belt and Water Pump has been changed?
    By Chunklamb in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2012, 11:21
  3. Cambelt & Water Pump
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 00:48
  4. 3.0 v6 cambelt/water pump
    By bigsteve3.0v6 in forum Y & Z30DT Specific
    Last Post: 11th September 2011, 23:44
  5. Cambelt and water pump done today!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 23:57
