Results 1 to 10 of 17
Thread: confused over tyres
    Regular Member cockney16v's Avatar
    stoke on trent
    Default confused over tyres
    im after two 225/45/18 but i dont no if i need extra load or not,what the difference between 225/45/18 95 and a 225/45/18 91
    anyone no of where to get a reasonable price for two fitted in stoke on trent
    Full Member Big Sig's Avatar
    No, you don't need XL tyres. the 225/45/18 95 are xl tyres as is denoted by the 95 load rating. The 91 rated ones are fine for your 1.9 150.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Get the nt5000 from neo brothers, and then get them fitted at your local fitter
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by s_zigmond View Post
    THATS HARDER SAID THAN DONE IN STOKE ON TRENT, a lot of tyre dealers will not fit other peoples tyres, others want 25 quid a tyre to fit.
    Sodding Typical on Sea
    Agree 100%
    As for load rating the XL tyre has a reinforced sidewall which with our billiard table smooth roads is quite un-neccessary NOT!!!!!!!!
    XL tyres do tend to wear better too in my experience.
    As for fitting specialists go to mytyres.co.uk and check out the local fitters page it gives prices too which is an easy way to find a local garage.
    The Neutons are a stunning tyre in every way for the money one of the best around
    Regular Member tappetpaul's Avatar
    Jan 2010
    dundee
    I agree just fitted the nt5000 and what a difference! Paid £10 for 2 Tyres to be fitted! And they grip like you could not imagine!
    Quote Originally Posted by Derek Mc View Post
    There's a bit more too it than that
    They are primarily for heavy cars, which seem to be on the rise these days
    The entire tyre carcass is reinforced, using different materials from a standard version of the tyre
    They won't last any longer or shorter than a standard version of the tyre, as the tread material is the same
    Regular Member Wolflinn's Avatar
    Camberley
    + XL/reinforced tyres give a harder ride.
    Quote Originally Posted by Wolflinn View Post
    That's only because of the higher tyre pressures that are required
    I've compared standard and XL on vehicles that don't need them and there is no difference when the lower tyre pressures are used (but that lower tyre pressure would be incorrect for that XL tyre)
    The vehicle used was a Vectra C 1.8 on 215/55R16
    stoke on trent
    nt5000 not listed for a 225/45/18
  1. Confused
    Last Post: 25th May 2011, 13:35
  2. Now Im confused?...
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2010, 17:38
  3. tyres.. confused
    By Dwabo in forum Handling & Braking
    Last Post: 25th June 2009, 14:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused - Tyres..
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 22:35
