Thread: New Vectra! Couple of little problems, Fuse list anyone?
    Mar 2011
    Hmm
    Default New Vectra! Couple of little problems, Fuse list anyone?
    Hi all. ive just brought a vectra 2.2 ls 52.
    i have a few problems:
    Drivers window dont go down (can hear motor when press up not down)
    Boot unlock and door locks switch dont work on drivers door
    Boot unlock dont work on passenger door
    Passenger window dont go down using passenger door (works on drivers)
    Carnt get cruise control on i press it and it just flashes, maybe im doing some thing wrong?
    Has anyone got a fuse list so i can check these? ive looked online but no joy. found one for 2007 on vx website is this the same as mine?
    No handbook with car so carnt look there!
    Any help for any of these would be greatly appectiated!
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    hi m8 here is the owners manual, and the fuse listing start on page 247:
    https://www.vauxhallproductforum.co....icles/2217.pdf
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Mar 2011
    Hmm
    Thanks for that and the fast response!!!
    This looks like the new one though is it the same?
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by robert31 View Post
    Yip. Only one available now.
    Gazza4
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Try lifting the clutch pedal with your left foot as you engage the cruise, might just be the spring on the clutch pedal needing replaced which is a common fault and cheap repair too.
    Mar 2011
    Hmm
    Thanks for that mate it works when lifting pedal so i will get the spring now!!!!
    Any one have any ideas on the following:
    Drivers window dont always go down it takes one or 2 presses.
    Boot unlock and door locks switch dont work on drivers door.
    Boot unlock dont work on passenger door.
    Passenger window dont go down using passenger door (works on drivers).
    And i have just noticed heater dont work on 123 just on 4
    Rob.
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You'll fix most of those problems by cleaning the contacts inside the door switches, there's a howto on the forums somewhere, takes a couple of minutes to do.
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    The heater is another easy fix, its the resistor thats goosed. If you are handy with a soldering iron its an 80p repair with a new one from Maplins, if your not its a trip to the dealers for a new resistor pack, think they are around £20.
    Clicky The Linky
    Northampton
    Engine : A20DTH
    Mileage : 88000
    One question, did you buy the Vectra knowing you had these faults to fix or did you find them afterwards?
    Mar 2011
    Hmm
    Thanks ian-highlander, Cleaned all the connections and now all the door switchs work! had to solder a bit of wire on drives door lock switch to get this one working!
    Thanks dasArab looked a bit more into this and looks easy enough. Took out the heater resistor and meterd it out and the resistor is gone, so i will be going maplins in the morning for a new one!
    Merikiito, i new about the drivers window, unaware of the others! did get the car cheapish! glad so far they have all been easy fixs!
    The last problem is when i press the boot unlock on either door it just beeps and does nothing! any ideas?
    Thanks all!
  1. Let me introduce myself with a list of problems!
    By signum_jon in forum Engine & Drivetrain
    Last Post: 20th November 2011, 15:33
  2. recall list/ common problems
    By Tank988 in forum The 'Off Topic' room
    Last Post: 18th July 2011, 14:51
  3. fuse list needed to check windscreen washers
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 13:06
  4. couple of problems
    By CLOMP in forum Engine & Drivetrain
    Last Post: 1st April 2010, 19:51
  5. Couple of Problems :(
    By rio678 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 18:15
