Thread: Rear window washer
    Woodbridge
    Default Rear window washer
    I have to vec's, of different ages and neither work, are they prone to getting blocked or is it something more.
    Sep 2009
    Glasgow
    most likely the pump.
    scottish region
    Ming cleans the tailgate not the window can the jet be adjusted
    Sep 2009
    Glasgow
    yep. pin or bit of strong wire.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    its either the pump fella or the filter is blocked
    Woodbridge
    Ok has anyone got a picture of where the filter is, as I can hear the pump going but no water.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Filter is on the pump, mine was blocked above the front nearside wheel arch it appears under the front scuttle I cut the pipe there and ran the pump and it blew the rubbish out and then I used a joiner from Halfords
    Woodbridge
    Quote Originally Posted by paulhb View Post
    Does the scuttle need lifting?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes ut its easy to do
    Woodbridge
    ill have to take a look.
  1. Window Washer
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 19:14
  2. Estate headlight and rear window washer problem
    By henryf in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 22:17
  3. water bottle for rear window washer
    By hovis007 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 12:38
  4. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
  5. Rear Window Washer?
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 21:39
