Thread: airbag control module - removing
    Mar 2011
    Belgium
    Default airbag control module - removing
    could you advice me the easiest way of removing airbag control module?
    I detached the rear part of central console. Now it's like on this photo:
    Only difference between this picture and the mine situation is the mate which covers the module.
    what should I do the next? am i obliged to disconnect airduct?
    Mar 2011
    kent
    you don't need to do that you can get to the three nuts by moving the duct from side to side to make access once nuts are removed you can lift ecu from the bolts that stick up from the floor and gently persuede it out.. YOU MUST DISCONNECT BATTERY FOR ONE HOUR BEFORE DISCONNECTING ECU!!!
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Disconnect the vehicle battery and wait for approx. 30 min, this to allow the capacitors within the control module to discharge. Failure to carry out this operation could lead to the airbags/seatbelt pretentioners "deploying" , when you diconnect the wiring from the control module....
    Mar 2011
    Belgium
    thanks for remark.
    but my question is - how to remove airbag module in the easiest way being at the state as on the picture above?
  1. Faulty airbag module ?
    By CdRsKuLL in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2010, 10:00
  2. Leather Steeringwheel + Airbag Module ...
    By hans_vledder in forum Parts for sale
    Last Post: 26th May 2008, 09:11
  3. Please Help!!!airbag Ecu Module
    By mkp007uk in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2007, 15:07
vectra airbag control module location
opel insignia airbag ecu location
vauxhall insignia airbag control module location
vauxhall insignia airbag module
insignia airbag module location
insignia airbag ecu
insignia 2015 air bag ecu
2008 vextra airbag module
vauxhall insignia 2011 air bag module
insignia air bag removal
how to rempve the airbag computer in a vc vectra
vauxhall vectra 05 airbag module
vauxhall insignia 2.0 dti airbag module
airbag module for vauxhall vectra
vectra c airbag module removal
vectra c airbag ecu location
vectra c airbag module change
srs control module vectra
Where is the air bag mobile on a cectra c
vectra c airbag module location
