Results 1 to 10 of 11
Thread: Brake pad sensor light
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Brake pad sensor light
    Guys i need some help,the brake pad light(circle surrounded by small dashes)has started to come on my dash about every 2 days,once the ignition is turned off it stays off,even when the igntion is turned straight back on again.The thing is,my car is an 02 dti elegance and i dont ever recall my front brake pads having a wear sensor on them..Has anyone any ideas on this?Btw i had the pads replaced before xmas
    Mar 2011
    kent
    mines an 03 has sensor on nearside would start by checking connections
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by VECTRA HEAD View Post
    I had the same thing after changing my discs n pads so I just linked it out with some wire and the dash light went out. I have been meaning to fit a new sensor but have not done so yet. I think they are only 10 quid or so. I'm not that concerned really about a new one as I just keep an eye on my pads.
    The sensors can degrade through time and give intermitant readings.
    Mar 2011
    kent
    that,s exactly what i did didn't want to spend the tenner either
    West
    for the sake of a tenner i would just replace the sensor rather than bodge it
    Derry
    So you guys think that i do have sensors on my pads?Where do you get the sensors for £10,the stealers or fleabay?how do you wire out the light like you guys did?Thanks for your replies btw
    West
    sensor is on the front nearside & is a tenner from the dealer
    Trim : Sport
    Engine : Petrol
    Thats all the sensor is.... a wire through a block that gets ground down by the break disc. When the wire is ground through the dash light comes on...
    West
    Quote Originally Posted by DTI-Steve View Post
    correct
    Mar 2011
    kent
    you can also get them on ebay for £8.58 delivered wouldn't really call it a bodge when your skint your skint will replace when my pockets a bit fuller
  1. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  2. Brake wear sensor light??
    By collyb in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2011, 18:56
  3. Brake sensor light and smoke from rear
    By mrdouglas in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 16:49
  4. Replace brake warning light sensor - help
    Last Post: 12th January 2009, 18:28
  5. Brake Pad Warning Light and Sensor
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 19:18
