Results 1 to 10 of 11
Thread: spanner light and wont idle
    Mar 2011
    kent
    Default spanner light and wont idle
    hi again guys looking to pick a few of your brains again, car drives lovely then spanner light pops up once engine has got to temp(90) and wont idle doesn't go into limp mode. have removed and cleaned egr,boost sensor and maf was thinking replace maf? any ideas
    Engine : 1.9 CDTi
    Have you had the codes read?
    Mar 2011
    kent
    no being a skint flint trying to sort before paying 30.00 hence all the cleaning of sensors and valves
    West
    have you checked all the vac tubes & connectors for splits... i had a problem with my old dti years ago where it would be fine until you stopped in traffic & then die, turned out to be a vac connector had a split, cost pennies to put right.
    Mar 2011
    kent
    have checked them all can't find any leeks or loose conns have ordered 2 meters of new blue vac pipe to replace old ones as they look a sorry for themselves should be here 2mrow
    fingers crossed this will fix it
    Woodbridge
    Is there not a way to do a code check yourself? Then take a look at the list on here?
    Mar 2011
    kent
    tried the brake and accel pedal test don't want to know and i havn't got any code reader epuip can you suggest a good code reader that wont break the bank
    Woodbridge
    I can't lol, but I'm sure someone will throw a link up. there a threads about them on here somewhere
    Mar 2011
    kent
    turned out to be vac pipes replaced them with new silicone pipes total cost £6 now the car runs like a dream.. got to put this down to wear & tear!! as the car has done 105,000 no different than any other car i've owned
    West
    Glad to hear it was a cheap fix as i thought
  1. flashing spanner and wont start
    By jofenan in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 13:52
  2. why wont spanner light go off
    By japeye86 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 22:23
  3. Spanner on dash wont start please help
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2009, 02:25
  4. Pulsing Idle Then Spanner Light
    By R13hard in forum Engine & Drivetrain
    Last Post: 5th March 2009, 22:49
  5. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
