Thread: signum rear wiper motor?
    Mar 2011
    accrington
    Default signum rear wiper motor?
    hi, is the motor for the rear wiper on a signum the same as that on a vectra c hatch? as mines gone and need replace cheers
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by paulb70 View Post
    Is it defiantly gone as the rear wipe motor on the signum do tend to "stick " mine has done this in the past it just requires grease on the spindle coming through the rear window ...as for the motor being the same on the vectra i am not sure
    Mar 2011
    kent
    no its not i had the same idea as you,just had to replace mine got it second hand for 35.00 pounds the next cheapest one i sourced was from a breakers for 43.00 inc vat and delivery might still be able to find details if your interested.. 109.00 from perry's hence the second hand route
    Mar 2011
    accrington
    can get 1 off ebay around the 20 mark plus p&p, going to double check tomorrow as when click the stalk to put rear wiper on nothing, yeet hear the relay click when switch it off, and doesnt come on either when front wipers on and put into reverse, its stuck on facing 12o'clock on the rear screen.
    when say regreasing whats best plan to check? remove wiper arm from outside and grease?
    Edinburgh/outskirts
    Mileage : 38000
    Yes try and get grease past the plastic type sleeve ...worked for me
    Mar 2011
    kent
    if you can get one from ebay for a signum for 20.00 fairplay to you i couldn't find one n there for nowhere near that vectra c yes but i'm sure it don't fit
    Regular Member Keif's Avatar
    In the Garage
    My rear wiper got stuck today.
    Quick search on here and find the fix.
    Remind me why I like this forum.
  1. Signum rear wiper motor needed!
    By Whiplash450 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 14:10
  2. Rear wiper motor
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 15:02
vectra c rear wiper motor
