Thread: vectra c
    Mar 2011
    lingfield surrey
    Default vectra c
    I have a 2.2 vectra c with hard rear suspension as if people have removed the springs! does anyone know why this would be?...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It' not unknown for rear shocks to seize up
    Mar 2011
    lingfield surrey
    i have replaced the rear dampers and anti-roll bushes, still feels like there is no spring in the suspension... any ideas?..
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    do you want your springs back then?
    WGAF#5
    are you sure that the springs havent broken ... or someone hasnt fitted the correct springs for the vehicle ?
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    The standard 'Non Sport suspension' on the Vectra is pretty firm....eg our 55 reg Facelift Club spec car....eg It's difficult to 'bounce' the car to test the shock absorbers as a method referred to in for example the Haynes manual...
    A SRI with 'sportier' suspension set - up would be even firmer I imagine.....
    I have also heard that shock absorbers can become stiff.....suggested by a mechanic mate of mine who fitted me replacement KYB standard shock absorbers a couple of years ago or so...when the originals started to leak after 27K miles..
    An odd wear pattern on one of the rear tyres was also present...flats on the inner 35mm of the shoulder around the circumference of the tyre...which was causing droning like a worn wheel bearing....It wasn't necessarily wheel imbalance that could cause it ( Which it wasn't)...but stiff shock absorbers preventing the wheel from riding up & over bumps & the like properly...
    Full Member
    Timisoara, Romania
    6 Post(s)
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    Any tutorial for changing the front/rear shock absorbers? I've just bought all 4 of them and before putting them on, I'd like to know if there are other parts I need - e.g. I know there is a rubber bellow seal.
    Many thanks.
    Full Member
    Timisoara, Romania
    6 Post(s)
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    Many thanks.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
