Thread: 3rd injector plug
    Jun 2007
    chesterfield
    Default 3rd injector plug
    hi guys,
    deeply sorry if this info is on here, i've had a long search around and can't find the specific answer i'm after...
    can the 3rd injector plug fault happen on the 120 version of the 1.9cdti ?
    many thanks in advance
    Feb 2011
    derby
    Little bump as i need to know this as well and cannot find a definite answer
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    According to this the 120 suffers from the same fault too
    Field Remedy: 2049
    Subject: Engine Z19DT/H - Jerking, somtimes Trouble Code P0201-P0204 set
    Models: Engines: Option:
    Vectra-C 2004...2006,Signum 2004...2006,Astra-H 2004...2006,Zafira-B 2005...2006 Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL| Z19DTJ,Z19DT| Z19DTH| Z19DTL
    Complaint: Customer complaint about jerking sometimes SVS lamp on and DTC P0201-P0204 set.
    Cause: Software and / or fretting corrosion on injector plug.
    Production: Modified wiring harness has been implemeted in production as of engine numer: Z19DTH17000444.
    Remedy:
    In case of customer complaint reprogram ECU according TSB 1849 before changing any parts.
    If TSB 1849 will not cure the problem install field fix injector plugs (partnumber 93189918 / cataloguenumber 62 86 769).
    Mentioned Field fix kit does not contain of a 1,5mm² wire as mentioned in TIS 2000 wiring diagram.
    In case of concern please use 2,5mm² instead.
    FunctionalGroup: J - Engine
    Complaint Group: 06 - Failure Code Setting by Control Unit
    Trouble Code: P0201,P0202,P203,P204
    Feb 2011
    derby
    Thanks for the information, ill give it a go.
    Jun 2007
    chesterfield
    Thanks Neil,
    Going to give it a go this weekend, local stealers has 4 repair kits in stock so going to give it a try.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    If your engine number is after the number above and my car still has the yellow plugs then where do instant should Vauxhall have to replace if my engine is after the number stated above help please cheers guys
  1. Injector plug.
    By burbling1 in forum Diesel Engine related
    Last Post: 29th July 2012, 12:52
  2. 3rd injector plug
    By kamar in forum Diesel Engine related
    Last Post: 26th March 2010, 14:41
  3. To those that have replaced Injector plug # 3...
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 18:52
  4. Injector plug
    By vcdti in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 00:46
z19dt p0202 0f
