Results 1 to 10 of 15
Thread: whats with the puff
    Regular Member bunsen1's Avatar
    suffolk
    Exclamation whats with the puff
    upon start up off the car, there is no problems, after around 10-15 secs of idling it will start to go lumpy as if struggling maybe a bit like its going to cut which lasts about 5-8 secs and then out of the exhaust a little puff of bluey white smoke puffs out and lumpy idle goes?
    maybe nothing maybe something and as always im sure the legends on here may be able to give me an insight
    thanks in advance
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    Sticky valve?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    suffolk
    what the egr valve?
    suffolk
    is that a definate or your 2 pennys worth mate? thanks
    suffolk
    Quote Originally Posted by plasma View Post
    Sticky valve?
    can any one elaborate on this for me?
    cheers guys
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    sorry posted that while i had five minutes on the mobile between jobs... Could be bad injector? sticky valve (internal engine valve). Which would possibly explain the bad idle at the same time.. Need someone with more knowledge than moi for a definite answer though
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would put some BG244 in the tank, works wonders as it cleans everything. If that does not work then you will need to look further
    suffolk
    thats ok mate i understand, thanks very much though!!
    suffolk
    Quote Originally Posted by merikiito View Post
    hi mate, whats the bg244, whats it do and where to get if possible?
    would say say it could more serious in long run terms?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
  1. Puff of smoke this morning
    By d_ghedia in forum Engine & Drivetrain
    Last Post: 28th March 2013, 21:28
  2. Little puff of Blue smoke on startup...
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 13th August 2012, 11:06
  3. White puff of smoke
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2010, 11:15
  4. Air con seems to have no 'puff'....
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2009, 18:20
  5. Puff of Smoke
    By MrBond in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 11:30
