Thread: Replacing Tie Rod and Tie rod end
    bristol
    Default Replacing Tie Rod and Tie rod end
    Hi All,
    Had some play in the driver side wheel, most definitely left to right play so hoping it to be a simple matter of the inner tie rod / tie rod end. Followed the instructions I have found from various sources and removed the original. When I removed the gaiter a significant amount of oil ran all over my arms and my drive!
    Does this indicate a bigger problem with the power steering/rack??? Have I ******ed up because I thought I could do such a simple job myself!!!
    Help please................
    Charlie
    Engine : 1.9 CDTi
    There shouldnt be any oil come out.
    bristol
    Think the rack must need a recondition. Found that the fluid level was well down so have topped it up for now to see how quickly it is leaking. Hopefully that will tide me over for a while as cant afford a replacement right now!
    Thanks for the reply.
    think youll find that the "oil " is actually the grease from inside the tie bar gaiter that lubricates it , much like a cv joint and gaiter
    bristol
    Thanks for the reply, but the amount of fluid that came out (probably a cup worth) was too much to just be the usual lubrication. I think the rack must be leaking fluid so topped it up for now and going to monitor how bad the leak is.
    Thanks for the replies,
  1. Replacing cim ?
    By Mr Owens in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 10:10
  2. replacing the REC
    By les287 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 04:14
  3. egr needs replacing?
    By family guy in forum Engine & Drivetrain
    Last Post: 20th April 2011, 10:41
  4. Replacing the CIM
    By Martyn21 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:22
  5. Replacing DMF
    By RikD in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 21:55
vectra c inner tie rod removal site:www.vectra-c.com
