Thread: Panel filter question.
    Regular Member Ben Chiles's Avatar
    Feb 2011
    Redditch, West Midlands
    Default Panel filter question.
    Sorry for such a repetitive thread, but here we go.
    Tempted to pop a k&n panel filter in and remove the pipe in the air box, has anyone come across any eml lights because of this?
    Any overfueling?
    Also is there a resinator box connected to the underside of the airbox, as with other vauxhalls - or not?
    Are all the airboxs in the vectras the same? - Can i get a panel filter advertised for a 1.8 or the likes and pop it in the z20net airbox?
    Cheers, Ben.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    I have tried various panel filters, done the airbox mod, drilled extra holes in the bottom section, tried a couple of enclosed induction kits and a BSR optiflow system. In all that time I have never had an EML come on, I started doing these when the engine was standard and now it is remapped I will continue with trying various induction methods and have no concerns at all..
    As for the different sizes of airbox I am unsure, somebody maybe able to help you with that one, or a trip to a scrapyard may show you.. I would not recommend modding the top half of your airbox though, this trumpet section is there for a good reason, to sort out and direct the airflow correctly over the MAF sensor.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Full Member Big Sig's Avatar
    Remove the lower trumpet in the air box, not the upper. I believe all the filters are the same except the vxr and very early 1.8's (2002 models, and not all of those!)
    South Central England
    13 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The MAF sensor has straighteners in the pipe aswell though, I didn't remove mine but did modify it, the reason being that it was clear from the paper filter that one end was being used alot more than the other and that doesn't make for best air flow. Can't tell you how, I would have to kill you all...
  1. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  2. K&n panel filter
    By Neil71 in forum Parts for sale
    Last Post: 7th December 2010, 09:18
  3. 3.0 panel filter question
    By g1jkb in forum Diesel Engine related
    Last Post: 24th April 2010, 17:33
  4. K&N Panel Filter
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2006, 19:56
