Thread: Spraying Question
    South West
    Default Spraying Question
    I should be getting my VXR rear defuser in the next couple of days.
    It will be going on my Silver Sri. I think i am going to go with black as a colour.
    Considering its low on the car and not readily visible, i am tempted to spray it myself with rattle cans. Planning on doing it in Satin Black... so its not too dull and not too bright.
    Advisable or not? The way i understand it is:
    1. Clean the defuser to get rid of any contamination.
    2. Give cans a good shake (ok boys... calm down)
    3. With smooth flowing movements spray all over
    4. Reapet with a couple more coats.
    5. Do it in mild weather!
    I know lots is down to technique... But using the above reckon its worth ago?
    Aidi
    Dec 2010
    liverpool
    you need to key it for paint, wet sand it with 1000-1500 grit wet and dry paper, dry off/clean, then do about 3-4 light coats of paint leaving around 15 mins between coats and do it on a mild/warm day
    Oct 2007
    Shropshire
    If the item is not new you will have to sand it first. If it is already primered you won't!
    South West
    It will be a brand spanker direct from Vx. Cheers for the tips. I think ill be ok giving it a go!
    Regular Member badback's Avatar
    Runcorn
    I did mine satin black, I just sprayed it as it came. It's hard to go wrong with satin black, I did several light coats and quite a heavy one to finish. It soon builds to a satin finish. The insert isn't that visible really so you'll be fine, as I say it's quite easy to spray with satin black.
  1. how much for spraying?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 13:16
  2. Re-spraying question?
    By Spider101 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2009, 13:02
  3. re-spraying
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 19:07
  4. Question Reference Spraying Vxr Valance
    By pords in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 21:12
  5. spraying
    By simon5800 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2007, 22:01
