Thread: canbus disconnection
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default canbus disconnection
    hi..
    can any of the canbus systems be disconnected so they dont show faults up on the dash?
    iv tried to connect my gid with opcom of a friends and it says theres no connection with the swcan. it will talk to the hscan and mscan but not swcan it also comes up with an abd sensor fault but the abs light isnt lit on the dash.
    it also comes up with broken bulb fault at the rear but all the bulbs are perfect
    thanks
    al.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    The can-bus system can't be disconnected because it controls the whole car. That sounds like a dodgey unit to me, mine did that, then worked for a while, then packed up all together. Have you cleared the ABS fault to see if it comes back?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    The swcan error was a blown fuse on the passenger side fuse box lol.
    Don't know about the abs, I suspect the bulb had been removed out of the dash as I don't get any warning but opcom comes up with a off side abs signal faulty or missing.
    Iv been told that the abs sensor is built into the hub?. Is this correct.
    Al.
    north east
    More likely the bulb has just been turned off rather than removed
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Al 22 dti View Post
    Al.
    the ABS light should come on when it selfs checks when you start the engine. If not then bulb has been removed or turned off
    it also comes up with broken bulb fault at the rear but all the bulbs are perfect .
    Double check because if the upper tail / brake light fails, then the lower tail light takes over the role of tail / brake light instead so you still have three working brake lights.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by roswell View Post
    im going to check the abs bulb with opcom today to see if its been turned off.
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. EGR disconnection on 3.0 CDTI
    By diesel dog in forum Y & Z30DT Specific
    Last Post: 6th September 2012, 07:01
  3. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  4. Battery disconnection - Help please!!
    By jujitsuboy69 in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2009, 10:56
  5. Air box mod & battery disconnection
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2006, 20:05
