Thread: How to change a thermostat 2.2
    Mar 2011
    MIDDLESBROUGH
    Default How to change a thermostat 2.2
    This is my 1st post and was wondering if its easy to change a thermostat on a sri 2.2 petrol?
    Iv heard its fairly easy but dont want to get half way through and get stuck
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi vx and welcome to the site.
    straight forward job drain system, remove lower radiator hose,remove the 2 bolts from housing and you are there.
    make sure you have a new seal ring (Just in case )when you fit seal ring coat it with a little silicone grease.tighten bolts to 8Nm. (don't be tempted to over tighten,refill cooling system job done.
    Mar 2011
    MIDDLESBROUGH
    Thanks for the reply, how much fluid will i need to replace it with and will i need to worry about any airlocks?
    Jul 2009
    Engine : 20 Dti
    7.1lt without A/C .
    7.4lt with A/C.
    7.6lt with A/C and autobox.
    use antifreeze 1940650/09194431,make sure you add a 50/50 mix .
    system is self bleeding,fill system run at a fast tick over 2000/2300rpm for about 30 seconds then let tick over untill fan cuts in,allow to cool and top up coolant to KALT/COLD (don't remove coolant cap untill cool it HURTS he he)
    Mar 2011
    MIDDLESBROUGH
    Thumbs up
    cheers m8 will give it a bash at the weekend.
  1. thermostat change
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 13:47
  2. thermostat change
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 12:52
  3. thermostat change
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 17:54
  4. thermostat change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 27th October 2012, 00:27
  5. Do i change my thermostat?
    By beggsy in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:59
thermostat zafira 2.2 petrol change
vauxhall vectra c 2.2 thermostat
change signum 2.2 thernostat
vectra c thermostat replacement
thermostat vectra c 2.2#scso=uid_WIiEXgAILO8KFNaDsAgJ3g_5:3614
holden vectra 2.2 thermostat
vectra c 2007 2.2 termostat
vectra c 2.2 dti thermostat location
vauxhall vectra 2.2 diesel to change thermostat
