Thread: Air con not working!!! What will it be??
    Regular Member degsy1234's Avatar
    Jan 2010
    Here
    Default Air con not working!!! What will it be??
    Hi All
    Tried to use my air con today but alas no cold air .. Rang the dealers to see if its covered and was told £59 to regas it and if it is a leak in any pipes or the compressor condensor it will be covered and get my £59 back. Unless it has been damaged by stone chips etc... Now whats your guesses on what the outcome is gonna be??? Booked in for a week on friday (April fools day )
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Have you had a look for obvious signs of a leak?
    Regular Member DarylAAS's Avatar
    South Shields
    look through the bottom grills on the front bumper.. the radiator straight in front of you is the air condensor.. look the the bottom quaters of it.. if it looks wet/oily/damp.. youve got a leak.. even if theirs a small spot chances are it gone
    Full Member Big Sig's Avatar
    Did you use it as you should over the winter?
    Regular Member Wolflinn's Avatar
    Camberley
    Had the same thing , leaks are fairly common. Got all mine done F.O.C
    Dont get to worried there is a high chance it is a leak,and dealer will be honest.
    Glasgow
    The majority of leaks are caused by not running it to keeps the seals lubricated for example running it every now and then through the winter.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to the suitably titled "Heating, Ventilation & Air Conditioning (HVAC)" section, Please use the proper sections for posting any issues/problems.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
