Thread: Front Brake Help Please
    Regular Member Telboy's Avatar
    Apr 2006
    Leeds
    Default Front Brake Help Please
    Im getting a groaning noise from my front offside caliper when I brake and release it and it is not clearing the disc properly after being released which in turn is causing a slight but very annoying squeal when moving slow or turning tight corners.I had it off other wekk to clean her but it is back again now and is doing my head in.Does it need a bit of copper grease on the sliders or has anyone any other ideas.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    [QUOTE=.Does it need a bit of copper grease on the sliders or has anyone any other ideas.[/QUOTE]
    yep exactly that
    Mine did this, dreadful crunching noise on applying footbrake; replaced under warranty
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Mine has been doing exactly the same thing for the last few hundred miles. It's fine at first but after a few miles with a bit of braking it starts to bind & make the noise, it's worse when turning right too. I've had the wheel off and given it a quick look over & all seems fine, the wheel turns freely (though I did it while it was cold) and there's plenty of meat on the pads & disc & no discolouration.
    When I get the chance I'll strip down the calliper and grease up the pad rear/guides & see if the solves the problem, but from other people's threads on here with the same problem it may not fix the issue.
    Others have changed the pads & discs and still get the noise, I'd hazard a guess it's indicative of a calliper that's on it's way out.
  2. New front brake kit
    By Rob12 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 21:29
  3. 302mm Front brake kit - all you need
    By Caveman_nige in forum Parts for sale
    Last Post: 5th October 2010, 10:21
  4. VXR Front Brake Kit
    By spoons in forum Parts for sale
    Last Post: 17th March 2009, 13:53
  5. front brake pads on gsi 3.2
    By effone in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2008, 17:40
