Results 1 to 2 of 2
Thread: Signum Middle Seat Stuck
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Default Signum Middle Seat Stuck
    The middle seat in my Signum has got stuck in the down position. Iíve managed to work out that the cable to release it has come away from the mechanism at the base of the seat, but I canít work out how to access that to put it right. I donít care if it can be put down and raised again, I just need it to come up again so I fit the travel assistant back in it and get it sold.
    easiest way is to remove the seat
    its held in with 2 nuts at the back ( 1 on each side )
    and 2 bolts near the front
    you should be able to do this without taking out the two outer seats
    HTH
  1. rear middle seat belt stuck i can help
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 12:26
  2. middle seat stuck down??
    By kenno31 in forum Bodywork & Interior
    Last Post: 18th February 2012, 20:15
  3. Middle seat stuck up
    Last Post: 10th September 2011, 09:27
  4. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  5. Signum rear middle seat won't move back up !!
    By cav595 in forum Bodywork & Interior
    Last Post: 17th March 2007, 22:50
