Results 1 to 10 of 11
Thread: DMF......?????
    Gillingham,Kent
    Default DMF......?????
    Hi all,we seem to have lost drive in old Vectra,it seems that the clutch is permantly disengaged...........engage gear and nothing,won't go forwards and won't go backwards....would this be due to a DMF failure or not.....?? Any light shed on this would be much appreciated.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by StuiF1 View Post
    I wouldn't think DMF. That just rattles and vibrated when moving the pedal. I'd say clutch. Is the gearstick easier to move than normal?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Has your brake fluid gone down?
    It could be the Hydraulic Thrust bearing.
    either way its a new clutch and while you are at it its worth getting the DMF replaced as well £650 all in
    Gillingham,Kent
    Fluid hasn't dropped...still on the max level,so dosn't look like its a leak. You can start the car and select any gear without pushing the clutch pedal.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What car do you have? Vectra C or B?
    Gillingham,Kent
    Hi merikiito,its Vectra C,2.0 dti,2002,with 130,000 on the clock.
    Sodding Typical on Sea
    is there any feel from the pedal when you press the clutch and do you feel any movement when you select the gear does the shift feel the same weight etc?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Does the 2.0 DTi has DMF? I don't think it does. So I would say the clutch has had it
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    My mate had a vauxhall van a while ago where the gear linkage kept popping off at the gearbox end. You could simply move the gearstick through the gears without changing gear, Magic!!... until you needed to change gear.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    2.0 dti does have a dmf, well the one ive got does. If it was the dmf i would imagine it would still slighlty move but would rev like hell. More than likely the clutch is knackered.
vectra c 2.0 dti wont select gear when started www.vectra-c.com
