Thread: squeaking noise from the rear of the car
    wales
    Default squeaking noise from the rear of the car
    i have just fitted new shocks to the rear because the car made a squeaking noise thats doing my head in......took it for a test drive and it the same..it is from the rear drivers side.when i sit in the boot and bounce you can hear it squeaking.it i coming from behind the rear wheel but i cannot see what.i have used wd40 on every thing but still the same.....
    can you help.....................
    Are the shocks like-for-like replacments?
    Take a look at both rear springs, especially the opposite side from the failed shock, it has probably snapped at either the base or top
    wales
    yes like-for-like replacments, i will have another look at the springs but they looked ok.the squeaking was there before the new shocks anyway.
    A failed shock can be recognised by lifting each side of the car up, but use clean gloves so as not to mark the delicate body and paint work in this area
    That was how mine was traced, as on lifting the nearside and then dropping, the shock could be heard squeeking
    Repeating the process on the offside, and no noise
    The springs aren't so easy
    You need to lift each side of the car up, so that the spring is not under load, and can be inspected from under the vehicle
    Alternatively it can be done on a ramp
    wales
    i have checked the spring all ok...i have spraded ALL the joints with wd40 still the same.....
    what else can i do..?
    Regular Member kevcdti's Avatar
    North east
    My rear spring was doing the same noise,but I have my rubber spring seats removed
    Sprayed the springs with wd40 and turned them and its gone
    wales
    Quote Originally Posted by kevcdti View Post
    so you took the rubber out the top and bottom turned the spring the other way up ...and it worked?did you leave the rubbers out then..?
  1. Squeaking/odd noise
    By DaKemps in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 23:01
  2. Squeaking noise from Rear End
    By WeDesign in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2012, 21:12
  3. Squeaking noise
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2012, 11:04
  4. squeaking noise
    By deepak in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2011, 17:20
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
vectra c squeaky rear suspension
sqeak from rear of zafira
creaking from rear vectra c
vauxhall calibra rear suspension creak
chirping noise from rear wheel vauxhall insignia
corsa c squeaking noise at rear
vauxhall vectra creacking when sitting in car
squeak in rear suspension vectra c
creaking from back vectra c
squeaking vectra c rear suspension
vectra c creaking rear suspension
vectra c creak at rear of car
vectra c rear suspension creak
vectra c rear creaking
vauxhall zafira 1.6 2003 squeak from rear
citroen c2 rear squeak
squeaky noise from wheel vauxhall insignia
vectra rear suspension squeak
vectra c rear wheel squeak
vectra c rear suspension squeaking spare wheel
vectra c test rear suspension
vectra rear shocks squeaking
vauxhall zafira squeaking noise
vectra c rear bushes squeaking
