Thread: Auto gearbox
    VIP-Member vectracman's Avatar
    Jul 2009
    Glasgow Scotland
    Unhappy Auto gearbox
    Hi can anyone tell me how you can tell which auto box is in your car F33 or F40 having some problems ( jerky changes ). My car is Life estate 1.9 cdti 150 2007/ 07 29000 Miles.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    It should be marked on the case somewhere.... or you can ask your local Vx stealer or any of us with OpCom to do a VIN decode for you, which will tell you the original build of your particular vehicle.
    I believe a 1.9 should have an AF40 tranmission.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    It will be an AF40 box and a full fluid change wouldn't hurt for starters,including the fluid in the torque converter and cooler.
    Essex
    I'm no expert but, the most obvious way to check is that the AF33 is 5 speed, AF40 is 6 speed, so stick it in 'manual' mode and go up the box, hit 6 and its AF40, only 5 and its the AF33
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by Aikon58 View Post
    I got that done on my AF33... And WHAT a change.. totally different and very much smoother... I got it flushed through so that old oil in the converter could come out, and at the same time fitted an extra cooler for the transmissionfluid..
  1. Auto gearbox
    By maud2450 in forum Engine & Drivetrain
    Last Post: 13th November 2011, 17:13
  2. 2.2 auto gearbox
    By adiehitch in forum Engine & Drivetrain
    Last Post: 29th August 2011, 14:47
  3. Auto gearbox oil
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2010, 17:58
  4. auto gearbox?
    By no1golfer in forum Engine & Drivetrain
    Last Post: 24th July 2009, 22:09
  5. auto gearbox
    By cerbrious in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:04
