Thread: Brake lights work then fail after 15 minutes
    Feb 2011
    Altrincham
    confused Brake lights work then fail after 15 minutes
    Hi
    My brake lights work fine when I start up but after a while they stop working. When I turn the ignition off and restart they work fine again. I thought it may be the brake pedal switch so I installed a new one. It was not fixed. I replaced the brake light bulbs, indicator bulbs and rear light, bulbs. I though that fixed it but no. I cleaned the rear bulb clusters and the earth points in the rear. Still not fixed. What could be causing this?
    Paul
    Last edited by Wetdude; 21st March 2011 at 16:42. Reason: Sorry I posted in wrong area. Please delete
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    It may be REC: Rear Electric Centre.
    Feb 2011
    Altrincham
    Any idea where it is so i can take a look and check it
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    If you can, get your codes read. REC is in a compartment in the boot.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. brake lights work without key in ignition
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 13:27
  3. Brake lights work then don't then do then dont
    By Wetdude in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2011, 16:40
  4. MOT Fail Brake lines
    By fuzzbomUK in forum Handling & Braking
    Last Post: 29th September 2010, 21:13
  5. MOT fail due to brake pedal creep
    By baztheman in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2009, 15:26
