Thread: vectra c 2005 1.9cdti
    northern ireland
    Default vectra c 2005 1.9cdti
    was woundering can u put new bushings in the rear trailing arm??or do u just buy full arm??
    lincolnshire
    you can on the vec B so i'd be surprised if you couldn't on the C mate , try your local VX or motor factors for a price ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    New arms are dirt cheap on the bay but the quality isn't as good as the orig obviously!, I've done mine with eBay ones but kept the vx ones, Its only the outside bush that goes(AT THE WHEEL END) so when the outside 'poly' bush is available I will have them fitted to the orig arms & re fit. Steve (spoons) is on the case with bushes already fitted to his vec c vxr.
    northern ireland
    saw rear trailing arm bushings on ebay was just woundering is it hard to push them in???
    you need a special tool to remove them , same as you did for the rose bushed on the rear of the vec b
    the vec b tool was about £60
    http://www.workshopping.co.uk/produc...-vectra/VS720/
    this is the vec b one , probably similar for the vec c
  1. 2005 Vectra C 1.9cdti Elite estate - Auto box changed to manual
    By seanr28 in forum Engine & Drivetrain
    Last Post: 24th September 2011, 22:06
  2. Alternator removal for 1.9CDTI vectra 2005
    By Karl_claridge in forum Engine & Drivetrain
    Last Post: 31st October 2010, 19:20
  3. Misfiring 2005 1.9cdti 150
    By jackrussell in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 11:45
  4. 2005(55) Vectra 1.9CDTI SRI
    By SRI-150 in forum Cars for sale
    Last Post: 8th September 2008, 19:51
