Thread: im confused
    Regular Member nidgeboy's Avatar
    Sep 2010
    Liverpool
    Default im confused
    right i have the bits to get a dual exit on my 03 2.2 sri and have two center sections with y bits attached but they dont seem long enough. am i missing something
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Have a gadge at this.... the company/prices may be of interest or not.... but the diagram might be of use.
    http://www.cats-direct-shop.co.uk/ex....php?ID=391280
    Sep 2010
    Liverpool
    cheers for the diagram but there is a split after the cat but it looks like my is one piece upto the flexi
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    This is the problem..... you have a 'one pipe straight through' system and you want to do a direct swap to a 'one pipe in - two pipe out' system. I'm fairly certain it's not quite so easy. You may need to get a stock 'two out' system and then adapt the manifold end using your existing front end pipe.
    Sep 2010
    Liverpool
    so is the 2.2 preface cat included into the center section. i didnt think it would be that much work
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    One the diagram page,click Home.... Exhausts then scroll down, select Vauxhall Vectra and you'll need to Next it about 3 pages for the 2.2s ..... two or three variants depending on exactmodel, but again, the diagram it shows should help.
    The ones I looked at appear to have the cat directly fed from the exhaust manifold rather than having it further back.
    Sep 2010
    Liverpool
    this is my current set up and the red line is where the two centers i have only got up too so looks like i need some welding lol
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Bear in mind also, there might well be a difference in bore diameters.... you might need a reducer to fill the gap.
  1. Confused!!!
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 15:53
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
