Thread: fault code help
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default fault code help
    HI guys got these faults codes..
    B3601 - Key Capture Relay Circuit Malfunction
    (04) - Present
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    I know cruse control says NOT PRESENT but my cruise control dont work!
    The 1st code is a relay or something else. and is this a stalk of worse problem?
    when i do live data and press buttons on stalk it picks up the buttons been pressed but i dunno .
    second lot of codes are.
    B1330 - System Voltage Malfunction
    (00) - Not present
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    P1743 - <Unknown DTC>
    (60) - Intermittent
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (5A) - Not present
    P0070 - Ambient Air Temperature Sensor Malfunction
    (71) - Not present
    P0700 - <Unknown DTC>
    (00) - Not present
    AGAIN I KNOW THERE NOT PRESENT
    but they come back at least 3 times a week after beeing cleared so obviously there is a fault some were.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    bump
    north east
    Cruise control could be the clutch return spring, does cruise control work if you hook your left foot under the clutch and set cruise ?
    Ambiant air is MAF sensor, but out of interst when do all these codes appear ? eg after a weekend of no using the car ?? looks like you may have battery / alternator problems rather than all these faults.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    well its an auto and been having a few box problems that am fixing just replaced maf...
    ermm car does stuggle to start in the morning. just random to be fair
    ermm not sure about clutch as its an auto. lol. my fault for not stating that.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    what engine do you have petrol or diesel
    and what mileage has it done?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    2.2 dti 102000
    Sep 2010
    north east uk
    Not much help i know, but i always get this when i connect it to my reader "B3916 - No Communication With Alarm Siren
    (0F) - Not present"
    Alarm works fine though.
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
Opel DTC B3601-04
Opel B3601-C
b3601-04 vectra
b3601 vauxhall
https:www.vectra-c.comforumshowthread.php132917-fault-code-help
VAUXHALL B3601-Cb3601 fault codevectra c B3601-4p1743 opel vectra cb3601-c opelb3601-04 vectra ckey capture relay circuit malfunction vauxhall zafira vauxall vectra fault code b3601_04 vauxhall astra fault code b3601b3601-04 opeldtc b3601b3601 opel vectraopel vectra c b3601b3601 vectrab3601 vectra cOpel B3601-04
