Thread: problem with z19dth
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default problem with z19dth
    Keep getting the following code coming up on opcom and cant find much info on it, just wondered if anybody can help
    P0090 - Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation)
    (5B) - Not present
    opcom data shows the following, is everything looking okay here?
    Measuring blocks information:Battery Voltage14.0 VIgnition StatusOn 12VStarter RelayInactiveAPP at Idle Position (Accelerator Pedal Position)ActiveAPP Sensor 1 (Accelerator Pedal Position)0.96 VAPP Sensor 2 (Accelerator Pedal Position)0.47 VCalculated Pedal Position0%Desired Engine Idle Speed850 RPMEngine Speed851 RPMCamshaft Speed425 RPMIdle Speed ModifiedNOCalculated Air Flow52 kg/hMass Air Flow Sensor52 kg/hAmbient Temperature14 °CCharge Air Temperature31 °CCharge Air Temperature2.85 VCoolant Temperature46 °CCoolant Temperature2.73 °COil LevelLowOil PressureNormalEngine Oil Level StatusOkayB1S1 O2 Sensor Heater Temperature573 °CB1S1 O2 Sensor Heater PWM2%B1S1 O2 Sensor (Bank 1 Sensor 1)879 mVBarometric Pressure102 kPaBarometric Pressure4.02 VBoost Pressure Command104 kPaBoost Pressure102 kPaBoost Pressure1.64 VPulse Ratio Boost Pressure Solenoid Valve75%EGR Position Commanded (Exhaust Gas Recirculation)100%EGR Pulse Ratio (Exhaust Gas Recirculation)4%Swirl Level Control Solenoid Valve Pulse Ratio79%Throttle Position PWM Servo Signal5%Desired Common Rail Fuel Pressure30.21 MPaCommon Rail Fuel Pressure30.32 MPaCommon Rail Fuel Pressure1.15 VRail Pressure Control Solenoid Valve PWM31%Rail Pressure Control Solenoid Valve Current0.81 aFuel Metering Solenoid Valve PWM41%Fuel Metering Solenoid Valve Current1.42 aFuel Temperature24 °CFuel Temperature3.14 VA/C Information SwitchNot ProgrammedA/C Cutoff Mode (Air Conditioning)Not ProgrammedA/C Pressure (Air Conditioning)600 kPaA/C Pressure (Air Conditioning)0.9 VA/C Relay (Air Conditioning)Not ProgrammedBrake Switch 1InactiveBrake Switch 2InactiveClutch SwitchInactiveVehicle Speed0 km/hVehicle Speed in Cruise Control RangeInactiveVehicle Acceleration0.0 m/s2Cruise Control Tip SwitchInactiveCruise ControlInactiveEngine Torque5 NmTorque ControlInactiveRequested Torque (Traction Control)0 NmRemaining Oil Life46%Engine Oil Change WarningInactiveMalfunction Indicator (MI)OffService Vehicle Soon (SVS) IndicatorOffGlow Time RelayInactive 12VGlow Time TelltaleOff 12VDiagnosis Glow Time RelayInactiveMain Injection Timing-1.4 °CAFinal Fuel Injection Amount7.5 mm3/stkOdometer Value198.225 kmTank Sensor2.38 VFan Control 1InactiveFan Control 2InactiveFan Control 3Inactive
    Regular Member ALAN B's Avatar
    Dec 2010
    East Lothian
    Is you car running ok?
    I had the same code 2 weeks ago and it was the fuel pump that was on the way out, not providing enough pressure. Had to change the fuel pump to sort it out.
    Could also be a faulty sensor if your car is running ok
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Only problem I've had is sometimes sluggish upto 2k then it flies, no starting problems at all. Doesnt show any elm or warnings on the dash.
    Anybody else know from the fueling results above
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    bttt anyybody have any clues?
    Engine : 1.9 CDTi
    Have a look at the EGR data and see if thats ok.
    Mine was flat below 2k so gave the egr a clean and it now drives perfect.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    is this what you mean
    lincolnshire
    EGR failure is known to cause lack of power upto 2k but doesn't always throw up the EML dude
    Engine : 1.9 CDTi
    Thats it yeah.
    It should change quite a bit as you drive/rev the car
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    finally figured out why the code kept coming back, there was a pipe coming from he fpr to a part at the back of the engine and the jubilee clip was undone, so after a few days of driving checked the errors and its not come back.
    was gonna get the injectors tested but dont have to now
    Nov 2010
    Denmark
    Hi.
    I have the problem that my Z19DT judder, especially doing the regen. I therefore tried to record data with op-com, and there is something that seems a little strange, the value of the Rail Pressure Control Solenoid Valve, is zero in both % and current, is that not a fault? I can see that neillīs data is 31% and 0,81A at idling
    Regards
  1. Z19dth DMF
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 15:30
  2. Z19DTH 150 engine problem;/
    By kenzohusky in forum Engine & Drivetrain
    Last Post: 19th June 2011, 16:59
  3. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  4. z19dth TURBO problem ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 15th November 2007, 15:29
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
p0090-5b
z19dth air flow kg h on idle
rail pressure control solenoid valve circuit
zafira fuel metering solenoid valve rail pressure low pressure
z19dth rail pressure sensor
vectra c 1.9cdti charge temp -40
engine torque z19dth opxom
vectra c injection rail selanoid
malfunction indicator off z19dth
astra h 13td calculated air flow
z19dth o2 sensor
p0090 Z19DTH
