Thread: Has annoy had there front shocks go noisey? or knock?
    Regular Member MCD's Avatar
    NE Manchester
    35 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Has annoy had there front shocks go noisey? or knock?
    Hi guys,
    I know my car isnt a VXR, but the full suspension set up is the VXR IDS system from factory.
    In brief, cars done 80,000 miles, its been lowered on Eibachs for 6000 miles now. Started getting noisey and rattly about 500 miles ago, thus far ive changed drop links and front anti roll bar bushes.
    Ive had wheels of, double checked brake calipers, body rim, track rod ends etc everything. All looks and feels to be in great condition!
    However, yesterday, its now change to a proper knock, its muffled, and does it over bumps, and you can feel it through your feet now. Defo summit moving. Granted, it does it less with sport mode on, and the shocks stiffen.
    If just got in now, jacked up car and had a good old shake of the front wheels top to bottom and side to side... all feels fine. I then put a bar under wheel and tried to bump suspension up and down... you can feel or hear movement at top of strut in top of wheel arch.
    While doing this i felt drop links, track rod ends etc, nothing down there is transmitting this noise, but in the top of the strutt theres noise.
    Pulled back the rubber cover in strutt.. all dry, and no leaks.
    So, please help? Any ideas? Would top mount bearings make this noise? I cant see how they can in my mind as they just plastic rings... can they knock?
    Or... worst still, does this sound like a simpton of the shocK? Ive also noticed road noise is louder too... summit a miss!
    Any ideas please would be massively appreciated? Im chasing my tail at the min!
    Mike
    NE Manchester
    35 Post(s)
    Engine : z20net
    Mileage : 80k
    Cheers chaps..... Drum roll!!!!!!
    CURED IT! Best way to explain...list.
    1. Rattle starts. Change arb bushes and drop links.
    Now this concerned me! I have a VXR roll bar as standard, the bushes are completely different to any other! They are in two pieces and have a steel rim. The vx supplied
    Part was all rubber and didn't close fully around the bar, but I ran with it as you can buy vxr arb bushes on their own, they come with the bar.
    2. Car drives much better, less noise but still rattle.
    3. Still bugging me so took shocks appart, greased bearings.
    4. Still noisey, handily getting alot worse.
    5. Poking around under bonnet, water bottle loose...'could it be so simple?
    6. Test drive..... Rattle gone.
    7 few hundred miles, handling ****e, bad knock
    8. Had it all appart today, arbs loose as ****! So fitted VXR ones on and a
    Brand new top mount bearing on drivers side.
    Result.... Perfect! Tight handling, no knock nothing.. Less road noise as good as when I got her! Test drove over 50miles enjoyed so much!!
    Just going to fit bearing on passenger side next week as only had one. That's it. So never anything wrong with arbs in first place... ****** water bottle and top mounts!
    Mike
    ____________
    Jul 2009
    manchester
    Glad you fixed it mate nothing worse than knocking noises on a car they can drive you insane
    Regular Member lostdog's Avatar
    Oct 2010
    Midlands
    Can you fit the same parts to mine? please? I have that sound too!
    Mar 2011
    Edinburgh
    so in a nutshell what exactly did u need to change?
  1. noisey shocks?
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2013, 21:02
  2. front suspension knock
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 13:31
  3. near side front wheel knock
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2010, 07:52
  4. Knock from front end of my 2.0 DTi
    By Vectra_Power in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2006, 16:51
  5. knock coming from front off side???
    By gizmo10119 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2005, 08:01
