Results 1 to 3 of 3
Thread: Inlet Manifold Done
    Regular Member Diesel Dude's Avatar
    Norfolk
    Default Inlet Manifold Done
    Replaced my inlet manifold yesterday on my 150 cdti, the linkage hadn't fell off yet but was very loose and a lot of oily sludge around the swirl flaps. When i got the manifold off I'm glad i did go ahead and change it there was a massive amount of play in the swirl flaps, at least 2mm of movement up and down so must have been loosing boost out of the loose flaps, and the linkage dropped off as i was taking the manifold off. Not a nice job to do but its all done now and when driving can notice a huge difference.
    Sodding Typical on Sea
    How long did the process take start to finish and any particularly tricky aspects? did you replace anything else or was it an off and on?
    Norfolk
    It took about 5 hours from start to finish, i replace the manifold and the manifold gasket,the egr gaskets and the throttle housing gasket, while i had it all apart i cleaned the egr valve and boost sensor. the only real problem i had was getting the fuel pump off mine was really tight, did it on the floor with just a trolley jack and axle stands.
  1. Inlet Manifold
    By Quirrel in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 12:59
  2. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  3. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
