Results 1 to 10 of 15
Thread: performance mods help and advice
    Barnsley
    Default performance mods help and advice
    i have a 2008 08 vectra xpii / xp2
    150bhp 1.9 manuel
    what mods are avalibe
    DPF - is this on my car ?
    disabled EGR - and same for this do i have 1 to disable lol
    im nt verry clued up when it come to derv engines
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    You could have it remapped, this could also remove the EGR and DPF (if it's a hatch then I doubt it will have one, have a search around the forum there are plenty of posts that tell you how to distinguish if your car has one or not).
    The air box mod is a simple one to do and can be quite productive, even with the standard air filter but it is better with a K&N. The K&N's are about £40 and the air box mod will take you about 10 - 15 minutes, again search the forums.
    A remap can cost you anything from £150 through to £400-500 depending on whether you have it 'live tuned' or not, there are plenty of recommendation on here for tuners.
    Barnsley
    i have just bought a dtuk box RED but may just sell it on as mas performance will re map with rr prints for £200
    just mainly after info weather i have the DPF and ERG valve things...
    already done airbox mod but using OEM filter and didnt realy feel much difference
    Sep 2010
    6 Post(s)
    Trim : SRI
    You will have an EGR valve, most cars do now-a-days. Most, nearly all hatchbacks didn't have a DPF fitted, except the V6 CDTI. MAS can take both of these out during the remap, even if you have a DPF it can coded out then removed, the insides bashed out or a different piece of pipe welded in.
    Barnsley
    Quote Originally Posted by lee_umney View Post
    cheers i think i donthave the DPF as for th EGR think ill leave it alone
    cheers buddy
    Sodding Typical on Sea
    As a hatch it won't have a DPF, a rolling road remap to about 190>200HP with or without egr is highly possible with the more important torque figure shooting up to over 300nm with ease there are lots of chart print-outs on this engine to show the options and results
    Liverpool
    To start..
    Airbox mod
    K&N/pipecross/green cotton panel filter
    Vac hose upgrade
    Tuning box
    also make sure your EGR valve and boost sensor are clean, plus running some 10K boost through engine will get some performance back.
    usuall as derek has said, you will reach 190-200bhp easily with between 300-400nm of torque.
    However if you want to go for more power, go for remap, de-cat, powerflow exhaust, egr removal, water methonal injection
    Nutron is the best man to speak to if you want to go over 200bhp
    Barnsley
    i keet thinking sell it /keep it cant make my mind up just miss the power of the vxr ,
    so far i have done the odd mod including vxr front end conversion and new rims etc
    so think i may keep and mod it
    Liverpool
    you can get the 1.9 to have just as much torque as a vxr
    Barnsley
    plans performance wise are
    airbox mod with green cotton filter
    full 2.75" system with sports cats and de cat down pipe
    re map
    add water wetter keep temps down
    what bhp should i expect ?
  1. popular mods style and performance
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:48
  2. performance car advice please
    By carlsondavid33 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 15:50
  3. What performance mods would you reccomend??
    By DaveW555 in forum Engine & Drivetrain
    Last Post: 23rd April 2010, 10:26
  4. Z32 performance mods
    By Padster72 in forum Petrol Engine related
    Last Post: 8th May 2007, 07:42
  5. 3.2Gsi Performance Mods?
    By danielpayne in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2005, 18:21
