Thread: Two more queries
    Kent, England
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    Default Two more queries
    A couple of unconnected issues with my 1.8SRi, 57 plate
    Firstly when I tried the quick clear windscreen tonight the air was coming out not much warmer than outside, surely it should at least be warm to clear the windscreen? I even tried manually setting the blower to 4 and hitting the aircon button and it was the same. When I use the aircon on cold its nice and chilled so I don't think I need a regas.
    Also whenever I'm coming off the motorway the stereo turns itself down, not a problem you might think but I like my music loud wherever I am lol. Is there a way to stop this happening as I assume the Vectra has the speed sensor thingy which is supposed to alter the volume to speed of the car?
    I've had the car 2 months and have so far only had minor probs like these and hope it stays the same, I'm lovin the Vectra
    Martyn
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    The quick clear will clear the windscreen even if the air is only slightly warmer than outside, this is normal.
    Some of the headunit's fitted to the Vectras have a "adjust for speed" function, it may be possible to tuen this off in the stereo settings or may require a tech2/vauxcom/opcom session. Is it a CDC40 by any chance?
    Kent, England
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    OK about the windscreen, tho its not very quick lol and I've got the CD30, it must have the VSS thingy tho cos I'm constantly havin to turn it back up lol
    Martyn
    Sodding Typical on Sea
    Hi Martyn
    You will need to access the setup menu and adjust the speed volume differences to leave volume alone. It sounds like the previous owner set it as per the factory settings for safety over volume
    Regular Member robengland9's Avatar
    Feb 2011
    london
    I found with the quick clear screen ...the air blasts so fast through the heater that it cant possibly heat up quick enough. I then found if you set manual heater blower to number 3 with heater on full temp.. the air flow is a bit slower then hotter air comming through clears the screen quicker.
    Engine : 1.9 CDTi
    The quick clear screen setting isnt just for heating.
    It turns on the aircon so it takes the moisture out of the air too and clears it quicker.
    And yes it sounds like the SDVC (speed dependent volume control) is turned on.
  1. Sat nav queries
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2012, 17:08
  2. Few queries
    By BBMadness in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2012, 21:21
  3. Help with queries.
    By weverall in forum Styling
    Last Post: 4th January 2012, 01:52
  4. just a queries.
    By Maxim007 in forum Engine & Drivetrain
    Last Post: 8th January 2011, 13:22
  5. Few Queries
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 01:27
