Results 1 to 3 of 3
Thread: Rear Screen Washer Issue
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    Default Rear Screen Washer Issue
    Well thanks to a monkey today he decided he loved the vectors rear washer jet and pulled it out. Can I replace just the jet it's self or is it a complete housing with the airel that I have to replace? Also the hose was damaged a little bit I can fix that without replacing the lot.
    Any part numbers / suggestions will be helpful
    Kev
    Nottinghamshire
    Rear washer jet attacked by monkey? Click here!
    The part number is on the second page for the hatch. It's 13166416 for the estate. The pipe won't need replacing if you can pull enough out to cut the damaged bit off and fit the new nozzle without pulling it tight.
    Dunking the end of the pipe (to the length of the pipe it needs to push on to) in some very hot water (hot air may melt it) makes it easier to fit the new jet. Once reassembled, check you get a good jet of water out of the nozzle and adjust it so it hits the screen in the right place.
    Also check the roof lining and under the car so see if you have any water dripping out where it shouldn't as this may indicate that the pipe is damaged somewhere inside the car.
    Jul 2009
    It was a ****** longleat monkey aswell thank you, there where 4 vec c's in the car park the same
  1. Rear Screen demister issue
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 08:54
  2. Rear screen washer problem
    By steveyd83 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2011, 21:21
  3. Screen washer help pls
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 15:24
  4. Replies: 9
    Last Post: 15th February 2010, 15:29
  5. rear screen washer trouble
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2007, 21:54
vectra rear screen washer jet instalation
