Thread: 1.9 CDTI Problems
    Mar 2011
    oxfordshire
    Default 1.9 CDTI Problems
    Hi all how are you? i'm new so be gentle with me please I really need help with my car it just seems to have no power at all at about two and half revs it gets gittery in any gear but anything under or over is fine but again after theres still no power and if i go any faster than 80mph i get a spanner and car light..... i've looked on your forum and i cant find the answer probably being blind though........ any help would be apricated
    Many thanks
    Kai
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Good starting point... Remove and clean the EGR valve, then refit, and check all vacuum hoses for splits
    West
    Make sure when you do go over 80mph your on a private road
    Check the swirl bar is still intact & find someone local who can read the fault codes
    Mar 2011
    oxfordshire
    Quote Originally Posted by tony-1977 View Post
    Thank you for the welcome and heads up aprently it had a new EGR valve fitted four thousand miles ago could it still be faulty?...
    and i will check the vacume pipes in the mornign if i know what they are hahaha
    Mar 2011
    oxfordshire
    only ever on private land when i go over the speed limit lol
    swirl bar??? now with out looking like a complete idiot what is that and where do i find it hahaha
    Mar 2011
    oxfordshire
    Perhaps i should add the thermostat has packed up, could that be causing my problems?
    Leeds
    Do you have a 120 or 150?
    Mar 2011
    oxfordshire
    How would i know? Haha
  1. 1.9 cdti few problems
    By Daz1987 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 20:24
  2. 150 cdti problems
    By zymon in forum Engine & Drivetrain
    Last Post: 5th March 2011, 12:40
  3. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  4. Problems with V6 CDTI
    By phil0464 in forum Engine & Drivetrain
    Last Post: 23rd April 2009, 23:08
  5. another 1.9 cdti with problems
    By marts cdti in forum Engine & Drivetrain
    Last Post: 4th December 2008, 23:27
