Thread: lack of power
    Regular Member Alerxt's Avatar
    Wolverhampton
    confused lack of power
    I hope someone can help with this prob. Car running fine ,then started it ok ,but when i tried to pull away there was a slight misfire and wouldn't rev freely ,jerking if i tried to drive it thought it maybe a glow plug ,although i changed them not long ago ,as it happened on a cold night and again in the morning ,tried to rev the engine struggled to get above 2500 revs then cleared itself and ran fine .started it at lunchtime the following day ok !! .Now the problem occured again put some injector cleaner in ....ran finwe until I filled up again cleaner again runs fine . i am thinking i've an injector on the way out .Oh had the 3rd inj mod done a while ago ,no lights on dash apart from once ,both emissions and spanner light . Going to change the diesel filter tomorrow . thanks in advance .
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I'll ask before someone else does, is the swirl bar off?
    Gazza4
    Wolverhampton
    Checked the swirl bar ,its on and functioning ok .
    Feb 2011
    lincolnshire,sleaford
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    egr valve ?
    Wolverhampton
    It feels as if its missing on one cylinder .Had EGR trouble before , has the same sort of symptoms as that apart from the misfire so thats why I ruled that out and am at a loss to think what it is . Would an injector if it was failing play up this way or just fail ? Do the glow plugs only work when the engines cold or are they controlled by the ECU all the time to help the emissions ?
    Feb 2011
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    my mondeo i had just went in to limp home mode when an injector failed had it re coded and away it went £50
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    http://www.vectra-c.com/forum/showthread.php?t=130008
    Have you checked third injector wiring
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by troutybrown View Post
    He had the mod done m8. On that note however have you checked the other injector plugs? Especially No. 4.
    Gazza4
    Wolverhampton
    Thanks for all your help just called the AA out to the damn thing . It was the ****** EGR Valve ,now blanked off . little info if anyones interested . If the valve is partially stuck open you'll have loss of power ,but if fully stuck open it will cause the symptoms I described an apparaent misfire .Anyway once again thanks for all your suggestions and help .
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:51
  3. lack of power
    Last Post: 6th February 2011, 20:18
  4. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
  5. Lack of Power
    By juggernaut in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 16:20
