Thread: help needed please
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default help needed please
    guys, the problem i had last year with the clicking from passenger side fusebox has started again
    symptoms are - interior and instrument panel lights flashing, no heater or blower has power is on and off every four seconds or so............no heated seats infact most interior electrics not working, however radio main screen clocks and dials are not effected.
    now pulled fuse 12 from dash fuse box and clicking and flashing stops- but obviously no power - also if i pull fuse no 9 for the central control unit the clicking also stops...................please help me diagnose this as it's driving me mad
    also its been doing it since last night................stopped by itself for around twenty mins today then started again.
    thanks in advance as always guys
    Jun 2009
    bradford
    nobody had the same symptoms
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    sounds like a relay on it way out or stiking mate
    Full Member paul.sessions's Avatar
    leighton buzzard
    if you remove the glove box i think there are relays up on the left directly behind where the fuses are maybe one is faulty or you have a short somewhere??
    Jun 2009
    bradford
    thanks for the replies guys, had everything out and there are only three relays in that fuse box...............pulled each one in turn and not one of them cured the faut............................
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
