Results 1 to 10 of 21
Thread: Steering Wheel/Exclamation Mark
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Steering Wheel/Exclamation Mark
    Was Out This Morning And On Came The Steering Wheel/Exclamation Mark Light..Ignition Off/On Then On Come Spanner/Car I Think It Was..
    Again On Come The Steering Wheel/Exclamation Mark.Did A 360 In The Middle Of The Road And Aint Sure...But Think I Felt Power Steering Go On Me..Tried My Code Reader And Nothing Showed Up..
    Been Back Out Again There And Everything Seems Fine Again...
    Anybody Any Ideas ?
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    check connections on alternator..............also fluid level
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by hairy31 View Post
    Where Is Fluid Reservoir ?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Tam was the speedo and rev counter etc on the dashboard working ok?
    Aug 2010
    Dundee-Motherwell
    Had A Daft Moment When I Was Getting Nothing Through Accelerator Mate...Dunno Bout Gauges
    Nov 2010
    East Midlands
    Trim : design
    I had similar with my 1.9 cdti (120) estate just returning home from a 100 mile no problem journey - stopped at a junction and warning light came on dash and lost power steering for a few seconds. Try power steering fluid and connections to power steering pump as previously suggested - but in the end replaced the alternator and battery and never had problem since. For some reason if your alternator is on the way out it affects the power steering.
    newport
    think the power steering is electrical, so if low on power thats one of the things that go
    May 2008
    Tyneside
    Power steering is electro hydraulic, electric motor driving a hydraulic pump. The pump and reservoir are under the front drivers side wing. Low fluid level will illuminate the dash fault light.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Tam80 View Post
    Remove driver's side front wheel and wheel-arch liner. It's behind there
    To top up, you'll need to feed a long funnel or similar down from the top, behind the headlight
    Jan 2010
    glasgow
    what scanner did you use id have thou it would have stored a fault code as said make sure the fluid is up
  1. facelift vec, yellow steering wheel light with exclamation mark on startup
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 16:55
  2. steeringwheel with exclamation mark
    By nadeem69 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 21:00
  3. Steering warning light with exclamation mark
    By bhod73 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2012, 10:23
  4. Steering Wheel with Exclamation Mark and more....... PLEASE HELP
    By Chris R in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2012, 11:06
  5. Replies: 7
    Last Post: 22nd December 2006, 23:23
vectra c steering wheel exclamation mark fault
vectra c steering wheel on dash
vauxhall vectra red exclamation mark
Opel vectra c showing symbol of steering on dashboard
vectra yellow steering wheel site:www.vectra-c.com
steering exclamation mark
opel exclamation mark steering wheel
