Results 1 to 10 of 13
Thread: smell of exhaust fumes
    Oct 2010
    bradford
    Default smell of exhaust fumes
    When I start my vectra 1.9 cdti 150 I get the smell of exhaust fumes inside the car has anbody had this problem if so do you know the cure for it thanks.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    in my experience,
    it means either your EGR is blocked / and or your inlet manifold is on its way out buddy.........
    Regular Member mozzer99's Avatar
    bristol
    as Grimo72 says, the inlet manifold swirl flaps wear out and let the pressure air and recycled exhaust gas out as per these pics. Take a look around the arrowed swirl flaps to see if the area is black with soot to confirm.
    There are other places to leak, but look at this first.
    Oct 2010
    bradford
    I had the EGR off about a month ago and cleaned it out then used a carbon spray cleaner its on a 55 plate and done 104,000 miles and still getting over 40 mpg.
    Sep 2010
    NE
    my siggy cdti 150 did it when i got it but once i changed the exhaust flexi pipe the fumes have gone
    Mar 2011
    Bulgaria
    Quote Originally Posted by murfcitygent View Post
    At the moment of smell there is also increased fuel consumption, after turn off/on coming back to normal consumtion level.
    Same question, for the same car and engine all the web. But no one owner post back on his thread about solution
    I got it too, however still no solution founded... ill continue looking once back home...
    p.s
    on 1,9cdti change the water pump every time you change the cam-shaft belt
    Rochford
    I had this and found my egr wasnt bolted tight enough as the thread had gone on a couple of bolts, causing exhaust gas to escape. If it is leaking from the egr you will see black soot around it. It must have been taken off by a previous owner and overtightened. I had to get some slightly longer bolts which sorted it.
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    my 150 does it, and it after checking the swirls egr and every other ****** place I could think of it went in for MOT.. THe exhaust flex is cracked.. That might just cure it
    East Ayrshire
    Trim : SRI XP1
    another similar thread on this running just now aswell, Same thing I'd think. In my case it was the flex pipe. Not an expensive fix
    Engine : 1.9 CDTi
    Quote Originally Posted by stevie16v View Post
    Same for me with my Signum.
    But on the plus side if you have a DPF (Like the Signum) the flexi bit is only £35
  1. DPF/CAT - Strong Fumes Smell inside cabing - CDTI 150
    By Vaux-Man-G in forum Diesel Engine related
    Last Post: 1st April 2012, 17:47
  2. exhaust fumes in car
    By wally10 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 13:46
  3. any 120 owners had fumes smell in car?
    By barney490 in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2010, 17:50
  4. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  5. exhaust fumes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 14:44
Vectra c exhaust fumes in car
vauxhall vectra diesel fumes in car
vectra 1.9 cdti exhaust fumes in car
exaust smell vauxhall vectra 1.9cdti
vectra 1.9 cdti engine fumes
opel zafira 1.9 cdti problems gassy smell
why do I smell fumes in my Vauxhall Vectra
vectra c diesel fumes in car
Vauxhall zafira 2008 1.9 ctdi 2008 fumes coming into cabin whats the fault
getting a stange smell of disol in my vauxhall vectra
Fumes in cabin.vauxhall zafira 1.9 cdti 2008
vectra smell from exhaust
fumes from intake on diesel car
vectra c diesel smelll
vectra diesel smell in cabin
fumes in car 2006 vectra diesel
burning smell in vectra 1.9 diesel fumesexhaust fume problems with an opel insigniavectra c smell fumes in carastra h 1.7 cdti heater smells exhaustsignum exhaust fumes in carAstra 1.9cdti 2007 smell of burning oildiesal fumes coming in through heater cdti vectra czafira exhaust gas smellexhaust fumes under bonnet astra
