Results 1 to 3 of 3
Thread: front tyres
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default front tyres
    FULL MEMBER NOW
    going to clean car tomorrow, my front tyres need replaceing soon but i was gonna put the rears on the front untill i get them changed, will i have to get them rebalanced? or will the be ok
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    depend on Wether the last time they were fitted on the rears
    only one way to find out look at wheels see if theres any weights on them then swap them over and see if the wobble
    If the fronts are down to 3mm, leave them there, let them wear out and replace
    Normal practice on fitting new tyres is to fit these to the rear, and to swap the part-worn rears to the front
    This gives you the maximum average tread, plus keeps the rears with at least 5mm of tread
    It also helps to reduce tread-blocking of the rear tyres
    Once you have fitted new tyres have the front wheel alignment checked
    If the car has not had a full four wheel alignment done, then do this instead, thereafter only a front wheel alignment would be required
  1. To put new tyres on front or rear?
    By mickydoos in forum Handling & Braking
    Last Post: 7th June 2011, 08:08
  2. Which tyres are better on the front (front wheel drive)?
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 3rd September 2010, 10:42
  3. new tyres, put on front or back?
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 20:42
  4. Nankang Front Tyres....
    By Signum_CDTI in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2008, 09:09
  5. Front tyres required very soon
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2007, 17:58
