Results 1 to 10 of 23
Thread: what is this on my dash
    Regular Member the fisherman's Avatar
    manchester
    Default what is this on my dash
    i have this sighn on my dash is it normal or is it a fault plz guys
    newport
    isnt that the brake pad low symbol?
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    yes
    Brake pad sensor if I remember rightly mate - means either your front pads are down to the metal or the sensor is ******ed. If it's the latter, and you've plenty of wear left, simply snip the wires and join them together. Saves a tenner on a new wire when you're more than capable of checking your brakes yourself...
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    yea......could also be wear sensor wire broke(as was on mine) just check your pads visually
    Regular Member themarbleman's Avatar
    sussex
    Brake pads have worn down,there are 2 types of sensor,long and short you will have to take the wheel of to check which you have,easy enough to replace along with the pads and from memory is about £17.
    manchester
    cheers guys,if i snip the wire will that light go of
    Mileage : 000
    As said above. You need to change the brake pads.
    The light might go off. BUT THE BRAKE PADS WILL STILL NEED TO BE REPLACED.
    manchester
    np ill grab a set monday cheers guys
    sussex
    You could try it,just make sure you insulate it properly from the elements.
  1. Facelift Dash Trim on a Pre face dash?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. Dash on, dash off Daniel Son.
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2011, 18:38
  4. LED dash
    By G4GAV in forum Styling
    Last Post: 10th June 2010, 22:44
  5. Red Dash
    By brian75 in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2009, 19:35
