Results 1 to 10 of 19
Thread: 2.2 dti thermostat
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default 2.2 dti thermostat
    i think mine might need changing?
    in this weather( between 5 and 10º) id say my car takes a good 6 mile ride( none motorway) before the needle even starts to lift.
    is this right or is it new thermostat time?
    regards
    al.
    Regular Member Innes's Avatar
    Plymouth
    The diesels do take time to get warm. When my thermostat went on my 2.2dti the needle on lifted to about 75 degrees after 45 mins of vigerous driving! I went on a 360 mile round trip a few months ago and it only moved briefly to 75 degrees whilst lost of over taking took place before dropping back down!
    Does your get up to 90 degrees at all? Perhaps your journeys are too short?
    Regular Member MrT1986's Avatar
    Falkirk
    I had this problem with my Vectra would barely get to 85 degrees after a long trip now after having the thermostat changed now sits nicely at 92 +- 1-2 degrees easy way to check is when you've just started the car after 5 or so minutes check the radiator and the pipes leading to it, they shouldn't be warm if the thermostat is working properly, and another thing is how long does it take the cabin to heat up if you set the heating controls to max? as the water flowing through the matrix will be pretty damn cold too
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My 2.2 DTi SRi takes about 5-6 miles of gentle driving to lift, then it's up to 88 degrees in no time.
    If it's driven hard, it moves within a couple of miles, then again up to 88 degrees in no time.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Mine takes about 7 miles too. Then sits at 85c all day.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Trip to work is 3 1/2 miles and the needle barely moves. cruising it's sitting around 90 degrees, 85-90 with the heater on.... I take that as normal and as far as I'm aware there's no reason to believe i have a thermostat problem am I right?
    120bhp 1.9 diesel
    West Sussex
    Quote Originally Posted by 19CDTi View Post
    120bhp 1.9 diesel
    2.2 dti 4.5 miles to work, needle hasn't even moved but warm (ish) air starts to flow after 2 miles
    Regular Member eaglepva's Avatar
    Up North
    2.0dti 4.6 miles to work.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    hmm.. mine took a good 9 mile to even lift this morning so i think il change anyway
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    i have a petrol but i reckon the following applies equally to diesels. The time taken to warm up is not a good indicator of failed stat. Its if it drops back down to bottom once full temp is acheived. If your stat is working this should never happen.
    Obviously if your car is taking hours to warm up this does probably indicate a problem
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
dti 88 degree thermostat
vectra c 2.2 dti thermostat location
