Thread: white smoke n powerloss
    North West
    Default white smoke n powerloss
    hi,hope someone can help me out
    when i start the car i get a lot of white smoke out of the exhaust tailpipe and sometimes when driving there is powerloss in driving
    Also the warning car with a big spaner is on dash for 30 secs or so after starting engine.
    any ideas ? it could be ta
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what engine is it?
    North West
    sorry ita a 53 plate vectra 2.0 DTI
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Sorry fella, white smoke usually means the bearings in the turbo have gone !
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by FIL 4822 View Post
    or unburnt diesel.
    Regular Member Innes's Avatar
    Plymouth
    It could be a split inter cooler hose but usually that causes black smoke. You say you are losing power so I would first check the hoses. They tend to split easily on the 2.0 and 2.2dti. Check by giving them a squeeze and look for cracks.
    [IMG][/IMG]
    Other posibilties could be the boost sensor needing a clean.
    Finally check your vacuum pipes for nicks and splits. The rubber connectors tend to go on the corners. Click on the DTI link in my signature to see about replacing them if needs be.
    Here is a pic to show you where everything is:
    [IMG][/IMG]
    Sep 2010
    north east uk
    Quote Originally Posted by Silver Vectra C View Post
    The spanner light coming on at startup & going out shortly afterwards is usually a sign of a glow plug fault. Maybe a good idea to check them first & see how you go from there.
    Plymouth
    Quote Originally Posted by mick.n View Post
    this is true. It may be the glow plugs. definatly worht a check. This doesnt explain the power loss though so still check your hoses and pipes as well.
  1. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. vectra 2.2dti hunting on idle. powerloss and smoke low revs.
    By fuzzyllogik in forum Engine & Drivetrain
    Last Post: 15th November 2012, 11:46
  4. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
