Results 1 to 10 of 22
Thread: Vectra 2.0t (Z20NET) - diesel sound?
    Sep 2009
    Slovenia
    Default Vectra 2.0t (Z20NET) - diesel sound?
    Hello,
    Does anybody knows why my vectra sometimes sounds like diesel if I start it from cold?
    Noise is not present always and if I switch engine off and then start again it runs fine.
    I change oil and filter every 10K miles (Mobil 1 0w-40) and my driving style is not too sharp. It is 2007 vectra with 60K miles on the clock.
    This is the noise
    http://www.youtube.com/watch?v=0KTexbAk2t8
    Can be this problem related with my poor battery? When it's cold outside It shows 11.9V on-screen before engine is on and if I start the engine voltage drops down to 9.8V ? After few seconds voltage is back on 14.3V.
    Thank you for help.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Lack of oil to the timing chain? (or is that the 2.2)
    When was the oil last changed?
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    don't think i would run that engine like that ..better get it checked out before some real damage occurs ...to me sounds like oil is not reaching the parts it should and can only result in one costly experience
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by tony-1977 View Post
    Z20Net has a chain too
    Sep 2009
    Slovenia
    Thank you for reply!
    Oil was changed 2 weeks ago...filled to one dash under MAX indicator (5,7l) and the noise is present since I have this car (one year). This noise only happens maybe twice in a month and always in the morning when it is cold.
    As soon I turn engine off and start it again, it is quiet as a mouse.
    Does this engine have "camshaft phase variator"? I was told that some similar noise on other cars comes from that thing.
    Tech2 doesn't show any faults and this problem is so rarely present that it can not be reproduced on service.
    Any advice?
    West
    I'm so glad my oil burner doesn't sound that bad
    Hope you get it sorted fella
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Quote Originally Posted by signumboy View Post
    agreed... its so not right, should not be ignored just because it goes away.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    11 Post(s)
    Can't play the youtube file at work, but chances are it's either a lazy hydraulic lifter, or a sticky tensioner for the timing chain.
    Either way, as said, don't ignore it.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    The 2.0T should be ultra-quiet at all times, including at idle. Needs checking out pronto.
    Sep 2009
    Slovenia
    this doesn't sound cheap
    How can service check either of this thing without stripping engine off?
    Can be this related with wrong/strange map on this car?
  1. Does this sound normal (Video Z20NET)
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 11th December 2011, 14:05
  2. Vectra c 2.0t Z20NET low power
    By 2Oturbo in forum Engine & Drivetrain
    Last Post: 15th November 2011, 21:23
  3. Can you make a diesel sound like a petrol?
    By ONEMINUTESILENCE in forum Diesel Engine related
    Last Post: 1st July 2011, 17:08
  4. odd sound from cdti v6 vectra
    By v6 sri diesel in forum Vectra C / Signum Troubleshooting
    Last Post: 6th December 2010, 21:11
  5. Can a s/s exhaust sound good on a diesel?
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 18:07
z20net sounds like a diesel
