Thread: Joining exhaust.what exhaust compound to use?
    Jun 2009
    Middlesex
    Default Joining exhaust.what exhaust compound to use?
    I need to replace the front flex joint section tomorrow.What exhaust sealing compound to use when joining to centre section.Any tips?
    Dobs
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Not done that one, but generally, if the section doesn't have a gasket, I use exhaust jointing compound or gun gum putty from any car parts shop.
    Jun 2009
    Middlesex
    Thanks.I did think of gun gum but wondered if there was a newer & better jointing compound to use when the sections sleeve together.
    Dobs.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    There's also Fire Putty, that's what I used for a home made sleeve and it worked perfectly, but that was further to the rear so less heat.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    I think you have to weld that joint mate as it takes the slack up from the engine that moves to the exhaust that does not so gets a lot of stick
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think the op is relplacing the whole section and not just the flexi on it's own.
    Any exhaust jointing paste will be fine mate, general rule is before the cat use gaskets and after the cat use paste
    Jointing compound should not be used before the cat
    Engine : 1.9 CDTi
    Use silicon as it wont go brittle and blow out.
    Regular Member mozzer99's Avatar
    bristol
    Maybe 'Dobs' is using one of the repair kits for the flexi section? I was surprised to see hundreds of these in all shapes and sizes on ebay.
    Aug 2010
    Luton
    that was my initial thought but as he has not come back who knows
    bristol
    Quote Originally Posted by lee gsi View Post
    I thought heat resisting silicone was only good to 300c. AFAIK diesel turbo exhaust gas can be 800c?
    What product do you use?
  1. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  2. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  3. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  4. Replies: 7
    Last Post: 22nd August 2007, 21:16
