Thread: MS Excel Experts
    Regular Member Damian's Avatar
    Market Drayton
    Default MS Excel Experts
    Are there any people out there with a bit of VB knowledge for Excel.
    Here is my first scenario
    I have got a yes/no selection in my Excel spreadsheet and on clicking YES I would like it to open a specific Word Document, on clicking NO, it does nothing.
    Second scenario
    A yes/no selection again and on clicking YES this time it opens a nrand new Word Document and automatically puts in some pre-determined text (meaning the word template does not have to be with the spreadsheet all the time) and on clicking NO, it does nothing
    It's basically for a H&S questionnaire, for example, if there is working at height the Manager clicks YES and this either opens the Working at Height Risk Assemsment template, or it open a new document and pastes in the wording
    Hope this make sense
    Regular Member Ian's Avatar
    York
    Okay, this took a little while -
    Copy the code below into the VB Editor for the command button that you are using on the excel sheet for Yes. If you want the No button to do nothing, then dont link it to anything.
    in the line:-
    Set wdDoc = wdApp.Documents.Open("C:\linked from worksheet.doc")
    set the path to the word doc that you want.
    'In order to use this code you must set a reference to the
    'Word object library by doing this. In the VB Editor click
    'Tools, References. Then search for Microsoft Word n.n Object Library
    'where n.n will depend on your version of Word.
    Dim wdApp As Word.Application, wdDoc As Word.Document
    On Error Resume Next
    Set wdApp = GetObject(, "Word.Application")
    If Err.Number <> 0 Then 'Word isn't already running
    Set wdApp = CreateObject("Word.Application")
    End If
    On Error GoTo 0
    wdApp.Visible = True
    wdDoc.Activate
    End Sub
    Hope this helps
    Market Drayton
    That was spot on, worked a treat. Can I be cheeky and run this scenario past you.
    The document will be given to a variety of site managers which would mean having to give each of them all the template word documents(and there could be 10 or 15) also and making sure they are all stored in the correct way so the hardcoded links work. They cannot link to a server as they may be onsite not connected to the network.
    Would there be a way to have some 'text' in the VB code so a new Word document would be created and some text be put into that document automatically thus negating the need for the hard coded paths. I am guessing no formatting will be able to be transferred
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by Damian
    Here you go mate, the solution posted gives you pretty much what you want with a small addition:
    Sub test()
    End If
    On Error GoTo 0
    Set wdDoc = wdApp.Documents.Add("Normal.dot")
    wdDoc.Activate
    wdDoc.Range(0, 0).Text = "Hello World"
    wdDoc.Range(6, 11).Bold = True
    wdDoc.Range(0, 5).Underline = True
    End Sub
    HTH
    Dave
    Market Drayton
    Cheers will try tomorrow
  1. MS Excel - Any Experts?
    By Aidi in forum The 'Off Topic' room
    Last Post: 22nd April 2012, 17:24
  2. Excel Macro's - Any Experts
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2010, 09:26
  3. excel help
    By shan in forum General Chat
    Last Post: 7th November 2007, 00:33
  4. Excel Formula Experts
    By Damian in forum General Chat
    Last Post: 22nd December 2006, 10:08
  5. Excel Help Please
    By jka in forum General Chat
    Last Post: 6th April 2006, 10:42
